Simon Hall
How are you ment to test the rcd of a lighting circuit if you can't test when it's live am I right in thinking you can just use the same figure as on the socket side as it's the same RCD thanks
Discuss Testing RCD on a lighting circuit in the Talk Electrician area at ElectriciansForums.net
Reply to Testing RCD on a lighting circuit in the Talk Electrician area at ElectriciansForums.net
