Testing spurs | on ElectriciansForums
Discuss Testing spurs in the Talk Electrician area at ElectriciansForums.net
SparkyMarky
:confused: Hello all,
I am a gas fitter and a domestic installer (limited scope) and was wondering what testing i have to do to install a spur (to fit a boiler) to a previously installed ring. Do i have to test the ring from the start as if i have installed it myself?
i would personally test the circuit your connecting into as you need to determine its condition, same as if you were connecting into an existing gas pipe. as well as fully testing your new circuit obviously, as well as checking the main bonding is in place to all incoming services. and the usual rcd protection etc.
hope that helps
rich
Thanks. it does!
Once you have tested the ring (including bonding Zs etc) would you then connect the spur into the ring and test from the spur as if it was just a spur originating from the consumer unit (ie connect line to eth at the consumer unit)
Reply to Testing spurs in the Talk Electrician area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
