Testing Times! | on ElectriciansForums
Discuss Testing Times! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Egham Surrey
Good evening gentlemen, some much needed advice is sought. I have spent the last 9 months exploring the finer arts of domestic EICR. This is as you can imagine - a steep learning curve. Whilst I feel reasonably confident in the domestic sector the sniff of my first commercial EICR sends panicky signals to my grey stuff!
My family have asked me to perform a EICR on a mid-sized supermarket and Postoffice. This has left me scratching my head wondering how to proceed.
THE INSTALLATION
4 x 3 Phase DB
1 x Main Post Office
Shed loads of circuits 100+
Unfortunately there are no previous records. A majority of the circuits have to remain energised.
What in your opinion is the best way to proceed?
Prospective Plan
Perform a though visual inspection
Catalogue each circuit on test sheet
Record Ze,PSCC , PEFC ,main bonding ect
Record R2 of each circuit
Test Zs of each circuit
In the commercial sector what is the norm when testing? Especially when circuits have to remain energised.
All replies welcome, it all helps in the continual training you gentlemen help provided.
Regards
Rich
first, to measure Ze, you need to isolate the installation and disconnect the earth. so it's a non-starter straight away, unless you do some of the work out of hours. second, if you are not completely comfortable with 3 phase, get someone who is to assist and share the take.
All installations are different so there isnt really a norm. You need to agree the extent and limitations with the customer. Any tests you cant perform (because they need to stay energised), you put a LIM on the cert. Test what you can.
He could ring DNO for this but that would be a long wait and waste of time..lol
What circuits have to remain energised. The reason for performing EICR is to ensure the installation is Safe for use. when I inspected and tested this type of installation I done the work out of hours, supplied temporary lighting and power via small generator, I do the inspection before hand and return perform test during the night time. I know a lot of people now do not test all the circuit and write on test sheet limitation, But please remember why you are there, I worry that the circuit I did not test could be the circuits that are faulty.
3 of the DB can be isolated, its just the Postoffice who insist on a unbroken supply. (Computers linked to main system) the testing will be started after hours 9PM. The three phase isn't too scary, though I might ask a more experienced professional to assist...
3 of the DB can be isolated, its just the Post office who insist on a unbroken supply. (Computers linked to main system) the testing will be started after hours 9PM. The three phase isn't too scary, though I might ask a more experienced professional to assist...
Yes probably power for time lock safe, I done betting shops / building society etc and they arranged for the computer to be taken off line while I tested the installation, they then re connected to network ready for business the next day. I ask post office manager.
The rest of the shop you can test ok.
Main thing to remember with 3 phase is to preform earth Ze on each line to earth and both Ipefc (prospective Earth fault current) and Ipsc (prospective short circuit current) on each line separately, then double the highest IPSC measured.
Do you have access to IR thermometer and torque screw driver. A thermometer would help you to check for loose connection in a live board as it will show up as an increased temperature, the torque screwdriver to correctly tighten all terminals.
Yep good shout telectrix about 3 phase if you are not sure then get advise domestics are ok but 3 phase is a different ball game ie measuring across the phases
Reply to Testing Times! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Or a combined fitting in each row.
nicebutdim
N
