In the case when there’s things such as battery storage and an inverter that charges are off-peak times or other things where there may be an inverter all alternative power source what do you do in terms of testing when the manufacturer specifies certain test could not be carried out that you need to do in order for the installation to be deemed safe And what you record on documentation
