Testing with String Boxes and Combiner Boxes | on ElectriciansForums
Discuss Testing with String Boxes and Combiner Boxes in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Scotland
Hi Guys,
Currently on a 3MW Solar farm job and will soon be coming up to the testing stage of the project. My question is, where do you do your test? There are String boxes at the end of every row, with isolators inside them for local isolation. There are then duct grade single core cables that go underground and back to the golden table where the combiner boxes and inverters are.
Do i do my testing at the end of the table in the string boxes so i can attach the earth cable to the mounting frame? Or do i do my tests at the combiner boxes as that is the final point for the strings, only there would be no test to earth?
Thanks in advance.
Reply to Testing with String Boxes and Combiner Boxes in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
