N
Noob2013
Hi all,
Does anyone know how to test the Earth Fault Loop Impedance on a monitored circuit such as IPS?
I have found in the past that even a Martindale Socket Voltage Tester can trip out the circuit as it is monitored.
I also found that no matter which way the neutral and line test probes were, the meter showed cross polarity. Is this due to the monitoring system?
Much appreciated.
Much appreciated.
