Testing Zs | on ElectriciansForums
Discuss Testing Zs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Do you do the same as the R1 & R2 test? i.e. connect the L + E in a connector block (with the power on) in a fig of 8 arrangement?
Seriously....do you understand what you have said there???
That will be a DEAD SHORT if you do that.
Get yourself a copy of GN3.
Reply to Testing Zs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
