Jon_
Could you tell me whether most of the tests carried out for a Domestic Electrical Installation Report would have to be repeated if a replacement consumer unit is subsequently fitted?
Discuss Tests for replacement consmer unit in the UK Electrical Forum area at ElectriciansForums.net
If it was you who carried out the EICR a few days previous I would use the same reads, however I would redo Zs and obviously any any new residual current device tests.Could you tell me whether most of the tests carried out for a Domestic Electrical Installation Report would have to be repeated if a replacement consumer unit is subsequently fitted?
Look at Best practice guide no 1 for a CU changeCould you tell me whether most of the tests carried out for a Domestic Electrical Installation Report would have to be repeated if a replacement consumer unit is subsequently fitted?
Downloads
The OP is asking WHAT test he should do before swapping the CUI assumed testing before, I think the op meant: testing first, cu swap, after cu swap was a full test necessary. But always test first.
Reply to Tests for replacement consmer unit in the UK Electrical Forum area at ElectriciansForums.net
