Texecom Alarm System | on ElectriciansForums
Discuss Texecom Alarm System in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
H
hutch6447
Has anyone got easy do follow wiring diagram for the texecom premier alarm system? not installed one before Need Some Help!
Do you mean you have'nt installed a system before or you have'nt installed a Texecom? Alarm systems are basically the same , it's usually just the programming that differs.
texecom systems are different, iv just finished installing one myself, if you pm me with the models of the keypads, control panel and any extenders i will find you the guides
Rob
some are very different beasts,you can normally google a texe manual,tho i think oldtimer might have a few texe ones on pdf,i think he uses premier,or it might be tel,i cant remember..
Without giving to much away on a public forum , in what way are the different ?
Ignore that question your reply crossed my post . I use Three b/band and it is so slow.
the principle is the same,as electricity is,but a simple domestic panel to say a panel you fit in a bank and everything in between have different values for monitoring a device,some systems have anti mask features where as the detector knows if it cant see what its protecting and reports this locally and remotely,different programming features,different ways of connecting remote modules ,signalling,it can be complicated at times..
Thanks for that I must confess mine are most r8 stuff.
if you still havent got the manuals pm me you details and what panel it is you need, i have them at home will email em over later
Reply to Texecom Alarm System in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
