Texecom alarm | on ElectriciansForums
Discuss Texecom alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
keniff
east sussex
Hi guys I have a texecom veritas alarm I installed about a year ago, I'm wanting to move the bell box outside to a different wall but Im not sure how to bypass the tamper on the bell box so it doesn't bell up when I take the lid off, any ideas or help would be great!
It's about a year old, how would I access the engineer hold off if it did have it? I can't remember if the battery is sealed or if I can disconnect it when I get the lid off lol
Your very lucky, odyessy has engineer hold off....set hold off by manual...then remove cover and disconnect battery plug. Then reinstall
Reply to Texecom alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
That will only count when the alarm is active o/p said tamper. O/P doesn't seem to be in any rush to give more info, so I doubt anyone else will...
