Texecom Premier Alarm | on ElectriciansForums
Discuss Texecom Premier Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
H
hutch6447
Hi, short off it is my sister has bought a texecom wired alarm and wants me to fit it and to be honest I did a course about a year and a half ago on alarm installation but since then cause I was an electrician in the army and for past year been doing domestic electrician with elecsa, I haven't really touched alarms.
I have got her FCU in place to take the power from for the control panel but as for wiring it up I have done end of line with resistors got the bell box in and the keypad but it keeps coming up axillary tamper and I just cant remember if I have done anything wrong.
Has anyone got any download picture diagrams of set out instructions Help would be appreciated Thanks Matt.
Hi is there any chance you could send that info to my email address or post me a link to get it as cant get on alarm page it appears locked
Have you put a link into the tamper connection of the control panel? If you have done EOL wiring, then you will not of used the tamper circuit, so this must be linked out.
trhink adam's idea ( link the global tamper pair of terminals in the panel if it has them). also check that you,ve fitted the resistors correctly. 1 across the alarm pair of the detector, and the other in series. or could be a poor fitting lid on a PIR> this often happens when the walls are out of true.
The Texecom Premier panels do have an auxiliary tamper, and the error is stating that this is at fault.
If it was a PIR, it would indicate which zone had a tamper fault.
Link out all the tampers at the main circuit board. Including the bell box tamper, keypad tamper, global tamper etc
Ensure the tamper switch on the panel is also de-activated
This should solve your problem.
Then rewire each one up, one by one, you will find your problem.
i would also link out the PA also
Hi, right think i am nearly there alarm system is arming properly and no faults are displaying on the keypad you take the front off control panel and it alarms which is fine, remove any of the resistors from the PIR's and it alarms the tamper but I have given the system a 15 second walk out it sounds like it arms fine and the PIR's are powered but when alarm is armed you walk in front of sensors and it dont alarm as if the circuit is still closed but PIR is picking you up but checked everything I possible could any ideas?
Have you wired the resistor correctly in the pir and is it all the pirs that dont work
am i right in saying that this is a 2 wire connection over the tamper and and alarm contacts so what the problem the panel sees one resistor and when the pir zone contact opens it puts the other resistor in parallel
well at the moment only 1 pir wired in and all other zones are linked out, want to get this one working first before doing the rest.
Got the jumper links in for the resistors as per the instructions
Reply to Texecom Premier Alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
