Texecom Premier Elite battery change. | on ElectriciansForums
Discuss Texecom Premier Elite battery change. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Rolemark
Nottingham
I’ve recently moved into a property with a Texecom premier elite system. I’ve been given the engineers code and have read up on the alarm. It looks as though i have a Texecom oddesy x3 sounder which is wired.
I dont know if the system has been serviced as it looks fairly new. However as a belt and braces exercise i think i should change the batteries in the wireless pir’s, control panel and sounder.
Can anyone advise what batteries the Odyssey x3 sounder takes, please?
Reply to Texecom Premier Elite battery change. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
