Texecom Premier Elite. EXP 1,1 tamper fault. | on ElectriciansForums
Discuss Texecom Premier Elite. EXP 1,1 tamper fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Bristol
Good morning.
Fitted a texecom premie4 elite 64W over the weekend.
Only one problem and that is I have a EXP 1,1 Tamper fault that I am unable to clear.
Looking on various sites it points towards the commissioning jumper still being in the commissioning position.
Checked this and the jumper is in the correct position left and centre.
Any suggestions?
I have emailed Texecom the same question but just trying to clear up ASAP and move on.
I would loop out all tamper circuits at the panel, reset panel and if fault is clear then add one circuit at a time until you find the fault.
get meter on d.c. volts. + probe to bell +. - probe to 0V should read 13V. and - probe to tamper return also 13V.
Reply to Texecom Premier Elite. EXP 1,1 tamper fault. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
