G
Guest123
Many thanks to nickblake for originally posting this in a thread.
Paper
The outer insulation has failed on the black sheath of the cable, and in one place the insulation on the inner live wire has also cracked off. This cable is in a very poor state, and is unsafe.
The rule of thumb with old rubber wiring is
TRS
PVC twin
Older T&E wiring having similar construction to today's cables. Several versions exist:
PVC outer rubber inner cable can have its rubber ends sleeved to make it safe, as its only the ends where exposed to air where the rubber becomes brittle and falls off. Cable with rubber outer insulation can not be made safe this way.
Paper
- Paper insulation
- From the WW1 era
- Very rare now in domestic wiring
- Paper is somewhat hygroscopic
- Pre-war paper cable is still in service in distribution networks, and causes a good deal of downtime
- The polychlorinated bipehnyl (PCB) used in old paper insulation is toxic, and the insulation should not be handled with bare hands
- Common in 1930s for socket circuits
- Used as exterior farm cable well after that
- Lead sheath does not make reliable earth connections
- Rubber inner insulation
- Tail rubber insulation tends to disintegrate, and muck accumulates on cable ends causing leakage
- Vulcanised India Rubber insulated cable.
- Along with imperial T&E, one of the most common historic wiring cables still in use
- Comes in 2 forms:
- Twisted pair, cotton/rubber insulated, with no outer sheath
- singles drawn into conduit
- Most VIR wiring doesn't include an earth wire, which is sometimes run as a separate uninsulated single.
- Rated to 60C
- Rubber insulation perishes, cracks & falls off
- Properties with VIR cable are usually in urgent need of rewiring, and may represent a significant safety risk. However some of the Jute / Hessian reinforced rubber cables that are often seen on consumer unit incomers are still often relatively safe.
- replace it as soon as possible
- don't move it at all, even small movement sometimes causes shorts.
TRS
- Tough Rubber Sheath
- Rubber insulated conductors with a rubber outer sheath
- Cab Tyre Sheathed
- Tinned copper conductors, each core insulated with VIR, & cab tyre outer sheath
- Single, Flat Twin and Flat Triple
- (I'm not familiar with this one, but presumably it looks like TRS)
- Cheaper alternative to copper
- Used from 1950s to 1970s, and old stock sometimes used into the 1980s.
- The insulation & sheathing is mostly the same as T&E - PVC for decades, may be rubber on older cable.
- A known fire risk
- Aluminium cable creeps, oxidises & fractures, all of which can cause fires.
- Requires special connections, do not connect to old ali cable using connectors intended for copper.
- Al requires a larger conductor size than Cu for the same current rating
- Presence of aluminium cable may be considered a material fact for insurance.
- The main problem with ali cable is its thermal expansion coefficient. Repeated temperature cycling causes it to come loose at connection points, and it then oxidises, and aluminium oxide is an insulator. Bad connections generate excessive heat and fire can break out.
- Each conductor has an aluminium core surrounded by copper
- An attempt to improve the properties of ali cable
- Significantly better than al, the surface oxidation problem is eliminated, creep reduced & the risk from cracking more or less eliminated
- PolyButyl Jute insulated cable
- Rubberised Hessian appearance to the sheath.
- The surface is these cables is quite uneven
- Commonly used for mains incomer insulation
- Lots of old PBJ is still safely in service
PVC twin
- 7/.029 T&E
- imperial 7 stranded version of 2.5mm² T&E
- used for socket circuits until unstranded 2.5mm T&E was introduced around 1970
- strands are 0.029" diameter = 0.74mm
- 3/.029 T&E
- imperial 3 stranded version of 1mm² T&E
- used for lighting circuits
- 1/.044" unstranded lighting cable also used
- Ashathene T&E
- Precursor to PVC T&E
- Lasts well
- PVC outer VIR inner
- an early T&E cable
- where the inner rubber has failed, the tails can be sleeved
- 2 core Twin
- no earth, used for lighting circuits, or power circuits with a separate (usually uninsulated) single run alongside to provide an earth.
