WayneL yep the furtherest point to me is the light point but as I said the Megger salesman key point was time saving asyou could test it at the light switch so you did not have to open up the light fitting now you say you can test it anywhere on the circuit so ok you have 3 twin sockets connected to a 16 circuit breaker the first socket is just below the board so I could test it their and test sy 10% of the circuit or I could go to the 3rd socket and get a reading of the full circuit and if I did the 1st socket only and then 3 months later I get a call saying there was no earth at sockets 2 and 3 then who do you think they would point a finger at also the scenario with the testing at the switch yep you can do it but what happens if the light fitting has no earth and jow public get electrocuted when changing a lamp ? so in theory yes you can test anywhere in reality and in my opinion it is good practice to test the whole circuit.
Also I have found a light point with no earth and trced the problem to the cable not being connected back at the junction box
Hi mate,
As Ringer pointed out - I was talking mainly about radials - you should normally take Zs readings at every socket and record the highest, so it wouldn't apply.
With a radial, if you link Line and CPC at the furtherest point on circuit then you can literally break into that circuit at any point (even the switch) and measure your Zs.
I know what your saying about measuring Zs at the switch - you're talking about measuring between 'Line' and 'backbox' (CPC).......my method measures either side of the switch with the switch 'open'.
This debate about the furtherest point on the circuit crops up often (with R1 + R2 and Zs) - and there isn't much in it.
If you think of the lighting circuit including the switch drop:
If you measure Zs at the light, you will include the two conductors that go to and from the switch - but not the CPC that drops to the switch.
If you measure Zs at the switch, you will include the 'Live feed' and the CPC that go to the switch - but not the 'switched live'.
So, each method misses a conductor out of the measurement - both of equal length to each other.
So, assuming 1.5mm T&E - Which method will give the highest Zs reading?........and should therfore be recorded.
