The older regs for Earth rods | on ElectriciansForums
Guest viewing is limited
Discuss The older regs for Earth rods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lounge
What were the regs for a 1990's built house ? See this pic of the E rod it's on a detached garage,TNCS so they split the install as they did then and TT'd the outbuilding ( Even tho no services) RCD in garage none in house, my question is how do you inspect the E rod connection ? Were the regs then more lax then[ElectriciansForums.net] The older regs for Earth rods or is it a poor install ?
J
Hammer and chisel time if the customer agrees.
I'd go with poor install.
526-04-01 in the 16th Ed is worded almost indentically to the current 526.3 17th Ed "every connection & joint shall be accessible for inspection & testing"
It's a relatives house TBH the board needs changing but he is a tight ---, I gave him loads of advice on his installation for free, then he went behind my back and got some numb nut in to put sockets in with no RCD protection, so I cut him loose, I just wondered what the regs said in the 90's mate thanks for looking.
J
If you cut the wire and tucked it back i reckon you could diamond out quite a nice clean hole for a conduit box type box cover with a small grove for a bit of flexi copex then just fill in over the copex and you have a reasonably presentable earth pit , all be it not ideal but a damn site better looking than a proper one now or what is there already .
Just mind you don't catch the supply cable !
If it tests OK I would leave it and make a note on any paperwork.
Wonder how well it tests covered in concrete, they tend to dry out.
What were the regs for a 1990's built house ? See this pic of the E rod it's on a detached garage,TNCS so they split the install as they did then and TT'd the outbuilding ( Even tho no services) RCD in garage none in house, my question is how do you inspect the E rod connection ? Were the regs then more lax thenView attachment 13470 or is it a poor install ?
J
Ditch the rod and connect the TNCS earth.........Thats if you are going to get involved of course.
Reply to The older regs for Earth rods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Mainline and thanks for the reply. My inverter is only fed from the mains supply over a 4 hour period at night and it does not have any tie...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
