The "Pinch method of stripping twin and earth cable" | on ElectriciansForums
Discuss The "Pinch method of stripping twin and earth cable" in the UK Electrical Forum area at ElectriciansForums.net
I thought this was how everyone stripped twin, I've never seen anyone using a cable stripper, except for swa and fine flex when bootlacing.
Folding knife and a bit of care, does for me, old School and the best all these fancy, waste of time and money tools .
The only problem with the knife method is too many apprentices either cut too deep and score the inner cores. . Or they slip and give themselves a circumcision :eek:
Insert the blade between the cpc and N push down once you have enough to hold onto with your other hand, pull the knife down until you have reached you destination, not taught on the Part P course I suppose.
Don't use a Stanley type knife, I was taught the folding knife method when I wer a Lad back in t 60s, never ever nicked any insulation, as far as I known, I just flogged my Buck folder to someone who appreciates a good knife. Stanley knife are good for one thing, cutting plaster board, and may be floor covering, that's two but who is counting?
I strip with a knife down the centre, and cut each tail of either side. Cleaner looking cable neck. We were taught this on the svq3 course, apparently pulling the earth stretched the conductor, I don't believe that... just a way of getting us to do it their way.
Cable neck, what's that? sorry.
Reply to The "Pinch method of stripping twin and earth cable" in the UK Electrical Forum area at ElectriciansForums.net
To the OP, I would ask the sparky to measure the "Ze" using the neutral and a phase. If it comes out low at 0.35ohm or so, then ask the utility...
Twin and earth on its own isnt going to meet the requirements for burial. Why not use Swa ?
