The RCD trips on a board that is dead? | on ElectriciansForums
Discuss The RCD trips on a board that is dead? in the Australia area at ElectriciansForums.net
M
mattmoo1974
Right, working in a shop adding a few extra sockets..
All old rewireable ccu some 1 had added a RCD garage unit to cover the whole installation(tailed into RCD feeds 1st ccu you no the drill)
Right im working on the 2nd ccu fed from the first..
I lock off the circuit im working on, test dead away i go, i cut in and trip the RCD??
Words of wisdom please :)
Unless I'm reading this wrong moo, an RCD will pop when you cut a circuit even if that CB is off. Disconnect the neutral you are working on as well as turn off the cb.
Is the RCD live at its incoming terminals? If so then this is normal, some RCD's trip when you cut into a circuit that is dead, i think they are known as passive, someone will correct me if i am wrong.
Cheers............Howard
What happens when you lock of the circuit mate? .... it's only the line (unless it's a multipole breaker) that's isolated. So when you are cutting in (assuming you mean a circuit cable) you are prob shorting that cable out.
Better to isolate the circuit completely (remove line, neutral and earth if possible to do safely) if you are intending to work on it.
The RCD is looking for a balance of the line and neutral. When the line is switched off all is ok unless you introduce a current into the neutral. When you cut the wire you cut accross the earth and neutral. The RCD senses that imbalance and shuts off.
Reply to The RCD trips on a board that is dead? in the Australia area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
