The Scotland England difference | on ElectriciansForums
Discuss The Scotland England difference in the Australia area at ElectriciansForums.net
scotsparky
Glasgow
I known this may start a debate however its a good question.
I have just had a look at Mr Marks Sparks install in the "Show us your installs " tread and notice a difference. When i served my time in Scotland we had to put a lockring at every coupling,conduit joint. However i noticed mr MarkSparks had none on his conduit. Is this an English thing and if so why??
in scotland lockrings are on 99% of installs but i think are a waste of time as long as coupling is tight. The job im on now is using conduit boxes with a allen key grub screw to tighten onto the conduit,even couplings with grub screw no threading,so good. But saying this above ceilings and stud walls ok but not surface conduit but got 110v threading machine even better.
Served my timed as apprentice here in yorkshire 1990 and we were taught to use lockrings as it reduces the risk of loosening from vibration etc especially as its can be used as an earth.
I got told that when the conduit was not the earth for the circuit/various circuits then no lock ring required but i must admit it did guarantee a good and proper connection and still use it today (make me feel better!!!!)
I have only been a spark since 1988 and still cant understand that we used conduit/trunking/swa sheath as a earth, give me a cpc per circuit and i can be sure (sleep well at night) its right.
ASH
suarface conduit lockrings purely for aesthetic reasons not waste time if pipe is hidden. Scotspark, every joint has a grub scew but cpc cable used for eathing purposes, dont bother with serated washers, also on market is conlock conduit accessories same idea as grub srew but push on n.ot that good though
even though CPC used for earthing how do you garentee the earth path using gub screw in the event of an Fault to the metal conduit.
you cant, the install is only as good as you've left it, tested thoroughly can sleep at night. Never going to be as good as threading but continuity is still achieved in normal conditions,suppose this product wouldnt be mass manufactured if not effective
Reply to The Scotland England difference in the Australia area at ElectriciansForums.net
