The timer switch in the sauna heater broke replace smart? | on ElectriciansForums
Discuss The timer switch in the sauna heater broke replace smart? in the DIY Electrical Advice area at ElectriciansForums.net
Calgary
Hello DIYers
I need some help reading the attached diagram.
The "Timer (60 minutes)" broke and I need to replace it.
First, for my theoretical understanding: the voltage between L1 and L2 is 240VAC. How is the timer able to connect to L1 and L2, while only one line goes into the Thermostat?
Second, do you know a smart device that can replace the "Timer (60 minutes)"? I read several articles, which mentioned it is the law that there must be a timer of max 60 minutes. But a smart device could easily handle the 60 minutes max.
Thanks for any advice.
Regards,
Gunnar[ElectriciansForums.net] The timer switch in the sauna heater broke replace smart?
Reply to The timer switch in the sauna heater broke replace smart? in the DIY Electrical Advice area at ElectriciansForums.net
Profile says UAE, but looks like a UK switch…. Do they use UK products over there? I will advise that the two switches use different labelling...
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
