The use of plastic wall plugs for the 18th.... | Page 4 | on ElectriciansForums
Discuss The use of plastic wall plugs for the 18th.... in the UK Electrical Forum area at ElectriciansForums.net
Spoon
Mentor
Nearly Esteemed
Lancashire
I was just reading an interesting post about the 18th when the above was mentioned. there seems some debate about this. I initially thought that the idea of prohibiting the use of them was stupid, but I'm not sure now.
[ElectriciansForums.net] The use of plastic wall plugs for the 18th....
http://www.swaonline.co.uk/files/ww/Install Protect _ ComplyFull Document.pdf
These walldog screws look like they could strip the hole easily in some cases.
Resin anchors? Hmm...are they not affected by heat? I've used them to tie brickwork and some other cases, but surely it's a bit fiddly and messy and time-consuming if you're just screwing some metal conduit to the brickwork?
Was there any report about Grenfell firefighters struggling because of dangling cables and fixtures. I'm just saying we do not know that all this reg stuff is just for economical reasons. Why did it take so long also to create this reg. Fires in properties being going on centuries years, nobody mentioned it then.
Another ploy to cater for poor training and poorly trained Electricians and Installers, as with the transformation to non combustible CUs
I guess it's fair to say that fires have changed over the centuries, and the electrical installations have changed too. We used to have buildings made of brick,stone,wood and slate, but now we have all sorts of materials in there including plastics,cladding, artificial wood-based products, and of course where most buildings 50 years ago had maybe mains electricity and a telephone or two we now have multiple extra cables never envisioned before for computers, telecoms, alarms, cable and satellite TV etc etc.
Also, some of the modern building methods, where every component is designed down to a minimum, means that premature failure can occur if not installed correctly. For example, if you have a house where the ceiling and roof joist are of the engineered "I"-beam type and you drill through these to run services, they are prone to failure even without a fire. Where the upright web is typically 6 or 8mm OSB, you can't expect this to have the fire-resistant qualities of a four by two. Yes, wood burns, but solid timbers in the old style will last longer before failing...and that's just the tip of the proverbial, imho.
That is a joke, yes?
Kind of, but the serious point is how can we have metal earthed containment where the protective devices are inside. Think about rcd protection on a TT system for the worst example. Relying only on the basic protection of insulation but no fault protection is not really ideal, but without an up front RCD that's what we would do.
Thats why everything has always been covered in plasterboard, even before such construction; even metal RSJ's have to be covered by it.
So plastic plugs no, but plastic trunking, conduit, fast fit boxes, etc etc etc are all ok, someone is having a good old ----ing laugh at us all, and all we do is bend over further and let the scam providers shaft us,maybe we should go back to the 4 inch nail bent over cables like in the good old days
So plastic plugs no, but plastic trunking, conduit, fast fit boxes, etc etc etc are all ok, someone is having a good old ****ing laugh at us all, and all we do is bend over further and let the scam providers shaft us,maybe we should go back to the 4 inch nail bent over cables like in the good old days
But plastic trunking is only OK if metal fastenings/clips are used.
Reply to The use of plastic wall plugs for the 18th.... in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
