There is still a bit more to be worked on plumbing advice | on ElectriciansForums
Discuss There is still a bit more to be worked on plumbing advice in the Plumbers Forums area at ElectriciansForums.net
There is still a bit more to be worked on I'm still struggling to finalise on the actual forums and categories. Trying to branch out a bit too with the bathroom fitters forums. Will see what that brings over the next 12 months, if it doesn't work it doesn't work and I'll pull it.
But i'm hoping it brings a few more regulars to the forum in general.
So the forums might move around a little bit.
Oh and the menu system is abysmal. In fact I'll get that done next.
There is still a bit more to be worked on to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to There is still a bit more to be worked on plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Bathroom Fitter in Newcastle Under Lyme Required Bathroom Fitter in Newcastle Under Lyme Required (testing this forum category out) Bathroom...
M
4” pipe lagging query?? Hi folks I don’t normally do much pipe lagging but I need to lag some rain water pipe work. Thing is I’m struggling with...
macka09
M
