Thermal Cutout Tripping On Emersion Heater | on ElectriciansForums
Discuss Thermal Cutout Tripping On Emersion Heater in the Australia area at ElectriciansForums.net
I
irishsailor
Guys
I have looked at a recently new fitted emersion heater, the thermal cutout has tripped 3 times within a few weeks, cna anyone shed any light on this and what tests can I do to find problem??
Chris
Code 2 whatever is the NIC advise,makes sense IMO...I think the cutouts were brought in when a tank boiled and burst,with the result of scalding water pouring through the ceiling below,scary... and not at all an unlikely scenario.
You need to be careful when obtaining replacements as I almost got one from my local CEF recently without the cutout,turned out their entire stock didnt have cutouts.....How many of us when fitting a new stat hang around to check it switches off ok?.....I always advise the client to check the water temp very carefully after I've fitted a new stat,and will always come back and adjust if required,I'd hate to be responsible for someone getting seriously scalded because the stat I fitted didnt have a cutout,so check carefully what you are buying.
Thermal cut-outs can nuisance trip if the electrical connections to them aren't good and tight. Loose connections get hot and the heat gets transmitted into the device causing it to trip. Otherwise check the control t/stat and thermal cut-out calibration is correct.
If it's intermittant and you can't pin the problem down maybe replace both the control t/stat and thermal cut-out to play it safe.
Reply to Thermal Cutout Tripping On Emersion Heater in the Australia area at ElectriciansForums.net
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
