Hi all,
Im bookedon the 2391-2 soon, and im reading through the course notes that i got from the kind gents on here, and workinmg through the examples.
Im trying to work outif the cable will withstand the thermal shock of a short circuit.
If i were to work out the PSCC, and then apply this to the adiabatic, and the resulting size comes bvack as less than that of the phase conductor, then is the thermal withstand ok?
eg, PSCC of whole job= 6Ka.
30A 3036 fuse,
6mm cable 25m long
impedance of L-N external = 230/600= 0.038 ohms.
r1+rn of 6mm cable is 6.16mohm/m = 0.154 ohm
total impedance of L-N= 0.154 + 0.038 = 0.192
fault current = 230/0.192= 1197.92A
square root
adiabatic = 1197.2 sq x 0.1
115
answer= 3.29mm (less than the 6mm phase conductor)
Hi all,
30A 3036 fuse,
6mm cable 25m long
square root
115
Thats pretty much it
looks good to me. just that if the cable is bunched or multicore, k =135.
Surely withstand should be calculated as a duration of time? Having to assess the effects of fault current on a given size conductor, with consideration of it's achievable disconnection time.
t = (k2 x S2) / I2
so with the values you have..
t = 1152 x 62 / 1197.922 = 0.3 seconds.
Therefore your disconnection time being 0.1 seconds means thermal withstand will be achieved (0.1s < 0.3s).
This is just my take on this.
I've enrolled myself on this course as well recently (want to achieve it before it disappears) so any course material/notes would be very gratefully received.
widdler
t = (k2 x S2) / I2
widdler
Yep, ....Based on initial and final conductor tempretures.
t = (k2 x S2) / I2
widdler
Same same, there's several ways, they all tell you the same.
Well obviously as it's just transposition of formulae.
But if a question asks you to assess thermal withstand from a fault between Live conductors, you want to verify the time. Not use a formula designed for sizing of "Protective conductors".
Widdler
I've got literally 100s of pages of notes, exam papers & project from about 2004 you can have.
They are all scanned images in zipped files, 11 files, biggest nearly 11Meg.
I'll happily email them to you if your email can handle it (some can't I think)
PM me your email address if you're interested.
All the reg references are to the Big Blue Book, but still good reading with loads of worked examples.
Andy
Really, And whats the time that a fault between live conductors must disconnect?
Regards Chris
Regards Chris
It must disconnect within a time that does not allow the permitted limiting temperature of the conductor to be exceeded.
South east
thermal withstand
Thread Tags
johnboy6083,
i=p/u,
