Hi all, could someone tell me how to test a thermistor on a boiler, do you use an insulation resistance tester?
Many thank`s
Many thank`s
Discuss Thermistor testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I wouldn't megger a thermistor, no.
Basically a thermistor is a temperature sensing device which can be used to break a circuit when a part overheats or, be used to trip another device on overcurrent etc.
A continuity test will confirm wether or not a thermistor is working properly.
Reply to Thermistor testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
