Thermostat Problem | on ElectriciansForums
Discuss Thermostat Problem in the Central Heating Systems area at ElectriciansForums.net
Reply to Thermostat Problem in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
I have had the DT92E for a couple of years and this is the first time this has happened. The receiver is in the loft above the room.
