J
J4EY
Hello again....I have one question that is confusing me slightly I think im overthinking it?!)
A mains operated room thermostat requires three conductors to enable it to operate correctly. Can you connect the thermostat to an existing two core and cpc cable and:
a) Use the earth
b) Use the earth and sheath with green and yellow
c) Use the earth and sheath with Brown
d) Not use at all
Would it be possible to explain why also as im a little confused?!
a) Use the earth
d) Not use at all
