Hi all
I have just completed an electrical installation consisting of 2 ring circuits, 3 lighting circuits, fire alarm circuit and a heating circuit. All went well apart from the heating circuit.....
I have installed 2 electric thermostatic panel heaters, a 500w and a 750w one. They are in two offices and within 10m of the distribution board. The total load therefore is about 5.5A. I decided on a B6 MCB, 1.5mm twin&earth cable on a radial circuit and connected then via individual FCUs. I used a 3A fuse on the 500w and a 5A fuse on the 750w heater.
All dead testing , continuity, insulation resistance, polarity etc was all ok. Live testing was also ok.
My problem is this....
As soon as the 750w heater asks for power, i.e. turning the thermostat up, it trips the RCD but MCB does not trip. I did try a bigger MCB but same response.
I have spoken with technical support at Dimplex and told them the wiring design. They advise it could be a faulty heater and to return it.
Before I do this does anyone else have any other thoughts as to why this would happen...
I am probably missing something really simple but can someone please advise as soon as possible.
