Thermostatic Valve
  • Thread starter Thread starter stevo1_l
  • Start date Start date
  • Tags Tags
    valve
Evening all,
I have a radiator that is not working properly. There is heat to the pipe but only a slight warmth in the radiator itself. I have checked the valve and tried bleeding, no signs of air just cold water. In the old house I had similar and removed the thermostatic valve and freed up the pin. I was hoping to try the same on this one but am unsure how to remove it. Any advice please?
Steve
Continue reading...
stevo1_l,
