THHN is supposed to be enclosed in conduit when behind drywall. Romex does not have the same requirement. Romex is "basically" THHN encased by a secondary sheath. Does this sheath really make that much difference such that THHN must be in conduit but Romex does not? Does that thin layer of plastic really make that big of adifference?
Context for the question: I am connecting a manual transfer switch to a subpanel. In order to minimize drywall work, I am mounting the transfer switch to the surface of the drywall. The subpanel is flush mounted (even with the surface) to the drywall. I am running the wires from the transfer switch through MC to a square junction box to provide a more 'finished' look. My plan was to run the wires through the back of the junction box the six inches to the subpanel inside the drywall without any conduit. If it were Romex, it would be allowed. THHN needs a conduit. Doesn't make sense to me.
