Thick Architect needs Help!!! | on ElectriciansForums
Discuss Thick Architect needs Help!!! in the The Welcome Forum area at ElectriciansForums.net
Moray, Scotland
All the RCBO information I see online only show the outgoing cable and the built in N (in) going to the N terminal connectors and FE wires . None show the return wires as in a ring circuit. The L and E wires are obvious but where does the return N connect to. The N terminal bar or to the out going terminal on the RCOB?
Thanks Andy. That's what I thought and just wanted confirmation. My client wants me to specify all the circuits to be from RCOB's. so I just wanted confirmation before drawing up the spec to go out to various sparks for quotations.
^^ you lost me................ ANY spark knows the answer and won't need to ask.
He’s a different breed - the title gives the answer. We are to doff our caps and not look him in the eye.
He asked question and got answer - everyone’s a winner!
What sort of spec is he producing, if he needs to know where the neutrals on a ring main connect to? I have had some major wirin specs, but none that have actually told us where to connect each wire!
would hate to see the full spec.
Perhaps multi skilled and it’s a ruse for doing the work himself - wouldn’t be the first time ‘one’ has slipped through the net!
We can say what we want - he ain’t coming back! He got what he wanted - typical man!
Reply to Thick Architect needs Help!!! in the The Welcome Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
