C
comptonspark
Looking at a rewire on an old cottage and just discovered that the walls are to be lined with an insulated plasterboard which is about 65mm think, so when fitted to the wall I guess 75-80mm from finished surface to original wall.
I was wondering how best to do the first fix since normal 25-35mm back boxes on the original wall will be too far back and i don't really want to use (very) long screws in the sockets!. Previously I've used drylining boxes with this sort of insulating board, but that was on stud walls so I could easily locate the cables in the void afterwards.
any suggestions?
thanks - Michael
any suggestions?
thanks - Michael
