Thick plasterboard wall? | on ElectriciansForums
Discuss Thick plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
rick
Bedfordshire
Not stricly an electrical question so apologies if this is the wrong place to ask...
Has anyone ever come accross a dividing wall which appears to be solid/thick plasterboard? Drilling in for fixing trying to feel for the cavity and drill bit emerged in room next door. Wall seems to be plasterboard like substance around 2-2.5" thick.
I've not come accross anything like it before, interested to know if anyone else has.
My old house was like that, built in the late 80's 2 pieces of plasterboard stuck together that was it. No stud. You could hear everything through all the walls and could only have sockets on the party walls
Gypson blocks ? found in older houses usually finished wall is around 2 to 3 inch thick. If you need a good fixing in this type drill the hole hoover out the dust spray in a little water put in a dab of expanding foam and push in wall plug and allow to set.
I'm sure it's called paramount partition wallboard. Or as has been said "eggbox wall. It was constructed with 2 sheets of half inch plasterboard held together with a grid type construction about one and a half inch squares and one inch deep. They used 0ne inch square timber to hold it together and a piece of one inch square timber top and bottom to make it sturdy. Before Dry lining boxes came out they used to get the position of switchboxes and knock a piece of noggin in from the edge during first fix. I think it is why dry lining boxes were designed.
There's a very big estate of nearly 300 timber frame bungalows a few miles from me where all the internal walls are paramount boarding, the metal switch and socket boxes are held in by 4 inch nails through the sides of the boxes and wedged behind the plasterboard, I've replaced dozens of them with dry liners. :)
Reply to Thick plasterboard wall? in the UK Electrical Forum area at ElectriciansForums.net
G
Waterproofing options for new shower room Hi, A newcomer here and thank you to anyone with the patience to read my drivel. I am renovating an...
Givey Tago
G
Unidentified noise in party wall Hi 🙂 Please can anyone help to identify this noise in the wall between me and my neighbour? Complicated but will...
shrewmouse
