Things I cant work out | on ElectriciansForums
Discuss Things I cant work out in the Talk Electrician area at ElectriciansForums.net
L
lofty84
When the emf in a conductor 0.15m long moving at right angles through a magnetic field, at a velocity of 2 m/s is 0.5 V, the magnetic flux density would be
I know the answer is 3.17 T but i dont know how to work it out
If a resistive and capacitive circuit has an impedance of 3 โ„ฆ and a resistance of 2.5 โ„ฆ, it's power factor would be
if anyone knows why the answers 0.83 leading could you show me why
If a resistive and inductive circuit has an impedance of 1 โ„ฆ and a resistance of 0.6 โ„ฆ, it's power factor would be
i know the answer is 0.6 lagging but i dont know why
please if anyone can show me the maths it would be appreciated :cool:
This site use to be helpfull, whats happened
Would love to help you mate, but to be honest its years since i did all that stuff. To be honest now i haven't got a clue. Try same post in Testing and inspection forum, there are some clever lads in there that teach etc and will be a bit more clued up with these type of calcs who may be able to help you. Failing that try the IET forums.
Cheers........Howard
its taken from the triangle same as power triangle where you have resistance reactance and impedance and the difference of the angle results in the pf, think its the opposite over the hypot so 2.5/3 = 0.83pf
would need to draw it out but works same as tru power/ apparent power etc.
got the three triangles somewhere see if i can dig them out
maybe its time you found somewhere else to contribute ;)
using the resistance triangle:
impedance is the hyp
resistence is the opposite
and reactance (tangent?)
so opp / hyp = 2.5/3 = 0.83
pf is the ratio between real power and apparent power and is found by the phase angle using power, voltage or resistance triangles (i thinks)
as for yuor first questuion, i have dug deep in my old course notes and found that the equation you require is e= Blv
e = induced emf (volts)
B= flux density (tesla)
l= length of conductor(m)
v=velocity(metres per second)
you need to transpose it, but i using your answer, i cant get it to fit. I was never any good at transposing anyway.
Reply to Things I cant work out in the Talk Electrician area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
  • 24/7~ASK#QuEstion>Why are flights so cheap in Turkey?+1-{804}-853-9001
    Why are flights so cheap in Turkey? Flights to Turkey can be cheap for several reasons...
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
