a while back i was working with an electrician who had this thing that you could clip 2 test leads into to zero your meter. also you could clip the same device on your plug tester or socket & see at the earth pin and it would spring onto the live and neutral pins so you could zero that too.
anybody know what it's called and where I can get one from?
cumbria
thingy to zero leads.....
Australia
ExArmy,
xraytek,
