squidge
I've built a garage recently, its now all waterproofed and I'm thinking of putting some electrics inside.
Just not sure exactly how I should run the electrics inside. I'm no qualified sparky and don't believe I know everything (far from it) but I consider myself competent on domestic installations (apart from stuff I've not seen before, but I only work on my own system so thats a moot point).
I've a spare 8 way CU that I thought about putting in the garage. Probably overkill but its free and in known good condition. I've always wired up sockets in a ring for the usual reasons, but I'm thinking now since I have so many spare circuits putting each of the 3 double sockets I intend to install in the gargage onto its own circuit and not bothering with a ring (since only one socket per circuit). I see no problems with this, anyone else?
Secondly, I wanted a dedicated double socket for outside tools such as lawn mowers and the like (but the socket itself located inside the garage). Normally I'd use a socket with built in RCD for this, but considering it has its own circuit and breaker in the (garage) CU, is this necessary? I've no problems putting one in if its going to be a little more sensitive when I slice the cable in half with a hedge trimmer, but I remember something about having too much RCD = bad, so I'd like to confirm this before proceeding with that part.
the installation will fall under the scope of part p so you will either need to inform building control before you start work and have them come out at various stages of the work or join a scheme for compliance with part p.
some bc`s charge upwards of £150 just to register the notice.
as for the advice to the wiring a bit more is needed to be honest ie what supply have you got? how long will the cable be run and how.
btw welcome to the forum :)
Hi. Couple of points, I'm assuming that you are taking a feed from the house CU, is this RCD protected?
If it is, you should a seperate circuit for the garage, from an RCD protected MCB with at least 4 or 6 mm cable if you think you might have heavy use. If not, any socket outlets that will be used for outside equipment MUST be RCD protected. To be honest, I would protect all your sockets, though strictly speaking, if they are clipped direct to the garage wall, (ie not hidden in plaster/behind plasterboard, you don't have to). Personally I would just run a 2.5mm ring through all your outlets unless you have a specific reason not to. If you run them individually to each socket though, remember to use a 20A MCB, not a 32 as you would a ring.
I'm normally would never be critical of people trying to help as they give it free and are genuinely trying to be helpful but please do not take too much notice of this advice.
Taking your feed from the RCD side of your house CU is not the best of ideas. If you have a fault in your shed then it will take all the house circuits that are on that RCD. The best way to do it is come off a Non RCD circuit, if you have it, and by running the cable in SWA the cable itself will not RCD protection, unless you have a TT system.
You can not just advise on a cable size without knowing length of run, loading, and therefore saying a 4mm/6mm is what you need, is not what you need, it maybe 10mm or even 16mm who knows only the designer would.
All socket outlets in a domestic situation, that are under 20amps NEED to be protected by an RCD, regardless of the possibility for mobile equipment under 32amp being used outdoors.
IMO it is a poor desgn to install 3 double sockets in a A1 ring, for such a small area and in a garage, unless your going to be using heaters, heavy duty machinery etc, then a A3 2.5mm 20amp Radial is more than adequate.
For your questions there are far too many imponderables to give you sound advice. As Phil said first off this work comes under the dreaded Part P notification and by the time you pay the LABC for this, it would be as cheap to get an electrician who is a scheme member to do it.
Even if you do decide to do the work yourself which your entitled to do, you will need to test and certifiacte the installation, which involves several complicated tests requiring expensive, calibrated test equipment, which in fairness you can hire, but can you use it after you hire it? and then complete the relevant certification
To be honest mate does nt sound like a big job(Unless feed for your CCU in the garage is going to be a nightmare) I just pay a sparky for the day if he uses your CCU(Condition Willing)
At least you get the paper work for this if you ever sell. By know means am i touting for work for some one, But i think the benifits of using a sparky will far out weight the cost.
Ring Final Circuit, one RCBO, all socket-outlets protected.
As malcolm says, all socket-outlets for general use by ordinary persons must be protected by 30mA RCD.
As above, your not changing a plug socket here your running a main feed + installing a new (2nd hand?) C/u + installing 3 new sockets + most likely lights. This is not a project to have a go at yourself. A number of things need to be taken into consideration before the first bit of materials is bought or the first run of cable is laid. Only if you have had training or know the regs + formulas to carry out this work you should leave it to the experts on this occasion.
Get a couple of quotes and ask if you can help him running the cables. You'll get a much better job done by a pro, safe, certificated, guaranteed and cheaper than doing it yourself + the costs of notifying the local building controll.
If you mention where you are I'm sure that there will be a sparky or two on here who could pop round and give you an estimate, with LABC notification included.
Why do people complain about non sparks doing their own work and then tell them how to do it.....Really annoys me this lads...
He needs to contact building control and they can see if he is competent himself. He surely can't be because he's asking how to design and install it.
Where do we draw the line on giving advice? On this occasion the job is to big for a diyer. Yes he will be able to run the cables, fit the sockets etc but will it be safe to energize and use?
May be the members should be given some guild lines for giving advise to none electricians from the admin? I'm not talking about is the forum or a member liable if the wrong advise is given and it causes injury. We could post on each thread that asks for our help "get an electrician in". This could be a debate for another thread.
How sure are you that the local LBAC will be able to make an assessment of competance of an individual?
Well I'd b suprised if they sent out someone who didn't know the regs....After all they are looking at Part P.
I just think that useing the website as a one stop shop fro advise is again helping the non qualified in their quests to take our work away from us!!
Paul it's exactly this.... I mean telling a spark from a non spark is very hard over the net....But when someone blatently comes on and says their not a spark I think no-one should be giving advise.
I've started a thread in the Arms (to keep it away from public view) about this subject. If anyone has opinion on this matter send it to me on a pm and I'll copy and paste it over. The thread will be put in the open forum later this week (if the mods will do so?).
I think that this place is all about advice.
Its a difficult one. Im fully qualified, (some how I got the 2391 !?)..however, I need advice on a regular basis (because im actually a village idiot).
Im glad I can come here and ask for advice, and advice has been freely given, and gratefully received. The advice I have received is in safe hands because even though I am a village idiot I have 'half a clue'.
I do understand where you are coming from Electricalserv in regard to advice 'dished out'. A little knowledge can be dangerous. But, what do you do?
From my experience this is a HELP forum. People advise here. People can not change the way others are going to behave. If someone has got it in their minds that they are going to rewire their house then they will do so.
Part P doesn't even come into the equation behind locked doors.
Advice is good. Thats why people log on to this forum.
You are completley right. We all need advice. My point is if a freely admitting non-spark comes online and asks how to wire his garage up should we be offering him our experience and knowledge. Its annoying because we see countless threads about sparks being out of work and this is how we repay ourselves....by offering our expertise to novices. Its the DIY'rs I'm talking about here not trainees or qualified lads...
SMB good post and in agreement. We on a forum can advise this and that but the bottom line is your not going to stop someone if they are determined to do something, all you can do is point out the dangers and hope that they take heed of the advice.
I hope if just one of my posts as made someone aware or made them think perhaps I should listen to that and get someone in, or not do it that way but this, and it helped them then I'd be more than happy.
SMB I have a feeling your intelligent ...but you hide it well;);)
You could wire it up Squide and there be nothing wrong with. I sure you probably can and have in the past and I'm sure its (worked) fine. Long and short of it is, If you want the paper work and no that its safe and tested get a sparky. If you do it and your house burns down and you have nt got a piece of paper to say it was done by a sparky to standards. Mr insurance company is going to say "Tough luck" . You ll save in the short term not in the long.
I hope this is a middle of the road answer.
Just be aware of the Pro's and con's.
And if you Electrocute yourself dont blame me :D
This forum is exactly that a FORUM the Admin /Mods ect ( as such do a good job) are there to prevent unsocial behaviour ect NOT to say who can and cant give advice IMO there are some problems/questions posed I wouldnt answer except to advise calling an electrician There are some in forum who ask questions and get caught up on one reg or the other (RCD,RCBO being the fav bs3036 fuses being another ) there are some who give sweeping statements you cant regulate What advice is given and who gives what advice Personaly I have had a couple of dozen " differences of view" with some guys but thats just like IRW guys opinions differ on most things except that Neil Lennon is a wee ginger trumpet
I need to wire some outside lights.
Ive just been digging around in the shed and ive found some string.
If I wet the string could I wire my outside lights with it?
Do I need to keep wetting the string in times of drought?
Grin.
Lets help where we can.
Its a forum open to the general public.
Im glad its here.
Agree with you, admin and mods do a great job.
I was referring to self confessed Diyers who want to do a new install in a garage, not electricians seeking advise on codes etc.
Reading this and others threads its plain to see that many of members walk away from giving advise for safety sake of the person asking. I believe this thread is one of them. Please get an electrician in.
To be honest he's not posted an update or logged in in nearly a day.....
Bet he's thought I'll do it anyway because I know what I'm doing.
Either that or he's in casualty after having a go!
Lol. He has had all weekend to Do It All, to make a nice HomeBase for his family to Focus on now that he has power for his BB&Q nights just in time for summer.
Thinking of wiring up a garage with existing equipment
Australia
squidge,
Knobhead,
