Stu1234
I've just had an electrician round to quote for an extra socket in the living room.
He suggested that the 'simplest' solution would be to drill two holes through to the exterior (outside) wall, one behind an existing socket in the bedroom above the living room upstairs that the spur will run off and one behind the new socket... then conect the two with a verticle cable running outside (clipped to the exterior wall).
This can't be right - can it?!
Apart from looking weird... what about the rain trickling down the cable from the outside into the hole in the living room wall - and new socket?
