A rainy Sunday thread.....
Right, this is MY house, which I rewired top to toe a couple of years ago (left some of the drops in where the cable was good to save on replastering).
A couple of weeks ago, Mrs Rockingits laptop charger died, so I found a new one from a Bay shop and life continued. Apart from the simple fact that this seems to only want to work from certain sockets. It's got me baffled. It doesn't follow a pattern of how they're wired, is the same across two split RCD separated circuits, needless to say that I've double checked all connections for tightness, everything passes every test, and the sockets which DONT work for the charger power everything else perfectly well.
So what I've got is a new (original part, not copy) charger which appears to work perfectly fine, a 'new' house rewire which seems to work perfectly fine, but certain combinations where they don't work together. (oh, and Mrs Rockingit giving me all the 'think you're a decent sparky, then?! teases).
The only thing I can think of beyond this is to get a scope and see if there is some bizarre waveform chopping going on which might affect the switch-mode psu, but then if that WAS happening, it would continue through the rest of the circuit from that point....and that's not the case!
Suggestions on a postcard.....
