Some readers might welcome a little explanation on this learning point.I'm assuming (hoping!) that the 3ph red conductors out of the MEM are suitably 'slotted'?!
You mean…what’s the difference between Eddie currents and Eddie The Head?Some readers might welcome a little explanation on this learning point.
it wasn't the start of a joke.Posted in anticipation
Eddy current: a localized electric current induced in a conductor by a varying magnetic field.
Eddie the Head: or just “Eddie”. Long serving mascot of band Iron Maiden. First appearing in 1980.
Eddy currants can be produced by passing live conductors through separate holes in a metal sheet. (Ferro magnetic) such as entering an enclosure.
This effect is negated if the conductors all pass through one bigger hole.
You’re raisin the bar there with your jokes.And eddy currants?![]()
Had breakfast with him once (Bruce Dickinson). Didn't mean to, but he insisted he needed help with what's best described as a mountain of bacon butties that had been brought to him, seemed rude not to. Nice chap and refreshingly clever.Yes…. Wooden “washer” between trunking and mainswitch. Oval hole. Not individual holes.
No eddies going on here.
Was a good fencer in his day, i heard
Swords... not planting wooden sticks in the ground
Don’t know who you offended there??
Anyway… can anyone read Roman numerals? I’m getting 1835
1735. You were close but no cigar.
I would guess he's the only rock singer that's also been a commercial airline pilot.Dickinson is a man of considerable talent.
Worthwhile remembering that before days of Simon Cowell, artists used to have to work their way up the ladder of success and stardom whilst supporting themselves however they could. One of my regular artists is a multi-platinum Brit Award holder who was discovered whilst doing pub gigs as a plasterer, Phil Collins was a window cleaner - etc. However, I feel a special place in our hearts will always be the knowledge that Sir David Jason was an electrician.There may be others, but none that spring to mind. Probably for the best as few rock singers would be suited to riding a bicycle, much less flying planes.
And Rod Hull was a tv aerial engin……..I feel a special place in our hearts will always be the knowledge that Sir David Jason was an electrician.
Apparently he also trained as a sparky after leaving the RAF.And Rod Hull was a tv aerial engin……..
Never mind.
