E
esc
Hi guys, would you like to have a look at this and tell me what you think, i'm a bit confused. Only had time to have a quick look at this as im away for a couple of weeks as of tomorrow, so couldn't delve deeper.
There's a lable stating PME, a 4mm earthing conductor that runs from the CU to the outside where it joins more conductor via a MET hanging from the wall and then dissapears along the row of terraced houses. As you can see there's a CPC with the incoming suppy and a terminal block with the DNO' fuse thats empty. CU's CPC's unsleaved, Terrible it is!
I can get a Zs at a SO near by (0.44 ohms), but when i try take a Ze, instrument throws a big question mark up before i can test and wont allow it. It's giving odd values of PD between L & N and L & E. Thought maybe leads have thrown a wobbly, but they check out at home.
Any ideas appreciated.
Sorry theres not more info at the moment.
