J
jonnyboy1
on a call from my mate last night that he could smell fish in his birds hairdressers but eventully found it to be comming from the electrics. i told him it could be a number of things but will come to look at it this morning.
so from picture 1 some bright sparks has dipped a 1mm into the tails which has burnt out and close to a fire. i managed to get the 1mm disconnected from the main switch but it will need replaced asap, the problem i have is with no isolation after the cut out. picture 2 shows the henly cut out fuse which is pretty old and by keeping with the law of the land i dont want to remove the cut out fuse, with its age it could disintergrate in my hand another reason i should not touch it. so im worndering if the dno should replace this free of charge with it being a fault, and that i cannot change the board as i have no point of isolation and with the install being in a dangerous condition.
the shop is on london road glasgow and just wanting some info or what to say to the dno before calling them. dno is brittish gas
