Thorn Lighting Triangle Tool | on ElectriciansForums
Discuss Thorn Lighting Triangle Tool in the Electrical Tools and Products area at ElectriciansForums.net
Market Harborough
Hi,
ive got a load of Thorn lights to work on and they all have triangle nuts on them.
does anyone know of a triangle tool that will fit?
this one below, is this just a standard meter cabinet size do you know?
or do you know where I can get a tool other than using a 5/6mm socket.
Wera 98 VDE Triangle Switchboard Cabinet Key Blade
You might find that 1/2 section of that socket will make it to wide to reach the triangle screw , in some cases . Although handy bits I never new existed for I.e street lighting access make your own like I did
[ElectriciansForums.net] Thorn Lighting Triangle Tool
Reply to Thorn Lighting Triangle Tool in the Electrical Tools and Products area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
