Been to customers tonight and one of the jobs on the list is...
Disconnect shed supply, shed coming down then reinstate when new shed built.
Currently supply is 2.5t+e spured from 32a mcb which also has a ring in there, all protected by 30ma RCD.
Cable is supported outside at high level with catenery wire.
All that is going in shed is 1 x socket, 1 light + switch. Cable run is approx 10m.
There are no spare ways in consumer unit to put it on it's own 16/20a MCB, and it's a right nightmare (no room all boxed in!) to split tails and add additonal RCD unit.
So not ideal and not the wayI'd like to it, but can it go back to how it was when I disconnected it - spured off 32a mcb with ring ?
Many Thanks,
Sy
Many Thanks,
Sy
