sythai
Hi there...
At a job yesterday and there were 2 x CU's. One of them being soley just for the heating system, 5 x radials and these were controlled via contractor/timeclock setup... the heat system consisted of a foil baked heating mat in the ceiling in each room (new one on me, but worked pretty well, made by ICI) with a stat in each room also.
At present there is no RCD protection on this CU, didnt have to work on that one so didnt affect me.
(This was on a domestic property)
But I'm thinking if this was done on a new install how would you go about it, as obviously you will need RCD protection due to the heating mat sat right on the ceiling. BUT then it wouldnt work because every time the contactor kicked in it would trip he RCD ?
Any thoughts please,
Sy
Not so sure the Contactor would trip the RCD Sythai, the 230v coil would be across L N and in balance, maybe it was forgotten, could be a bit more work for you?
I have seen these mats before , not for a long time though , if it were me id stick the radials on RCBO;s and the contactor on an mcb both via the main switch, cannot see why the contactor would trip the rcd though
Thanks chaps for your replies there... sorry about delaying getting back.
Unfortunately no extra work out of that one, just curious thats all.
Sy
sythai
Devon, United Kingdom
Thoughts on this please....
sythai,
sythai,
TrueNAS JBOD Storage Server
