Thread adapter (different pitchs) | on ElectriciansForums
Discuss Thread adapter (different pitchs) in the UK Electrical Forum area at ElectriciansForums.net
T
Tidy Max
Alreet chaps.
Does anybody know of a thread adapter that will connect gas/water fittings to electrical ones.
I.e. 15mm compression end to a 20mm lamp holder?
Soldered ends will look crap. Ive built a desk lamp out of copper pipe and used 15mm elbows and tees. I have some brass bc lamp holders with a 20mm female thread. I knew the compression end had a different pitch thread i just thought i would cross that bridge when i got there....
I am now there lol. Neither the wholesalers, plumbers merchants or commercial "we do everything under the sun" merchants can help.
I will be building a fitting soon with soldered joints but as for this one i am abit stuck :) ill check the links when i am back at my laptop! Cheers for the advice
Reply to Thread adapter (different pitchs) in the UK Electrical Forum area at ElectriciansForums.net
Capping off redundant pipework question. Hi all. I done some work for someone a few years ago and I've been getting paranoid that things haven't...
sammy67
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
