Threading conduit (no vice) | on ElectriciansForums
Discuss Threading conduit (no vice) in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
I forgot I had a small conduit job tomorrow and I left my conduit bender at work. This means I dont have any kind of vice to hold the 25mm galv whist I thread it.
Any imaginative ideas on how I can thread it without any kind of vice?
I have some clamps but no vice so to speak....
You will have to get yourself an electric threader! They come with one of these:
[ElectriciansForums.net] Threading conduit (no vice)
Unless all your pipes have 90 degree bends in them I wouldn't even attempt it.
Or you could use Conlock fittings, gross.
We have successfully done this once on a job by using an SDS drill bit shoved into one end of the conduit and then using the floor and your knee you can force the conduit up at an angle with the drill bit putting pressure on one end
This allowed us to thread 4-5 lengths on a job
Make 2 Vs out of some wood then clamp them in a vice. Not tried it myself but that's what I would do . I have metal V blocks that I made a collage that I find handy for clamping tube to saw it
Try and use a pipe wrench and wedge it somehow to keep the pipe from turning
Reply to Threading conduit (no vice) in the UK Electrical Forum area at ElectriciansForums.net
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
Hi Gavin, long time no see. Nice to see you are still about. Yeh retiring is a bit of a sticky process as there is still work on the books etc...
