DavidWick
hello,
I am after bit if friendly advise on 3-phase as don't have a lot of experience with it.
3-phase + N supply being fitted to a existing site as there is going to be a very large demand with house, outbuildings and swimming pool. the main intake and 3phase meter is in garage that is separate to house and outbuilding. there will be a 3phase consumer unit above meter to feed consumer unit in each outbuilding and the house
Client will have requirement for 3phase for some machinery in one of his workshops so this eliminates option of treating install as 3 separate supplies with 3 consumer units.
how do you go about getting just a single phase to house from a 3phase board- considering the load - as obviously mcb not large enough so would need to be main switch? if so do they do single pole? or do you use triple pole switch with only one tail exiting it (cant imagine that would be right??)
Sorry if obvious answers but cant say its something I have ever covered.
cheers
cheers
