BruceB
I have a couple of domestic clients with 3-phase PV and they could usefully use something like an Immersun to power a single phase load, but by monitoring import/export on all 3 phases, not just the one. The reason is that meters net the power consumption across the phases. Does anything exist out there in the domestic price bracket?
Elios4You PRO Bruce - aggregates generation and import/export measurements across all 3 phases. Calculates local consumption Has the same analogue output for proportional immersion control as the 1phase Elios4You. So, you can dump excess proportionally via the separate Power Reducer to a 1ph water heater or some such (certified, compliant, proportional immersion controller, 3kW resistive max load)
BruceB
Bath/Bristol
Retired Electrician
Three phase Immersun equivalent - does one exist?
BruceB,
BruceB,
