Three Phase MK Commando Combi Sockets | on ElectriciansForums
Discuss Three Phase MK Commando Combi Sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Deano
Good Afternoon folks,
16A TP&N IP67 Switchsocket Outlets
If there are a number of these required then normally they would be allocated their own dedicated circuit each, this is my understanding.
However, say for example there are 10No. required around the perimter of a roof to power a window cleaning cradle. Is there anything in the wiring regulations which prevents a number of these being connected to the same circuit? Becuase of the way the cradle will operate there will only ever be one socket utilised at any given time so there is no issue from a loading point of view.
My only experience with any TP&N equipment is that it is wired in its own dedicated radial circuit.
Any help appreciated.
Reply to Three Phase MK Commando Combi Sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
