I'm after your opinions, I posted the other day and have since spoken to my electrician and it appears I got a few bits mixed up, basically I'm converting a pub into a single domestic dwelling.
The building has 3 phase and earth is supplied by the armour from the main suply head.
We have now came up with the following plan
A three phase distribution board in the cellar next to the meter.
Inside this On one phase
- sockets and lights in the cellar (all surface mounted)
- outside power
-CCTV
-smoke alarms
On another phase
- A sub main to ground floor consumer unit
On the 3rd phase
- A sub main to first floor consumer unit
Would give me the future option to connect 3phase equipment
Ground floor and first floor will be standard consumer units with a isolator and RCBOS on all ways
The distribution board will provide whole system isolation and RCD to the sub main tails as these will be chased into the wall at one point but will still be less then 50mm from the surface.
It was also suggested 3way swg could be used as the sub main tails and metal clad consumer units could be used
I'm after your thoughts our opinions
- outside power
-CCTV
-smoke alarms
On another phase
On the 3rd phase
